bosoversa »
https://forums.nicoclub.com/bosoversa-u66967.html
Sun Jul 01, 2007 5:46 pm
well well. sorry guys, been soo busy. took the right side light out finally this morning, but had to do a bunch of other stuff, and ended up having to put it all back together. until i start documenting that one, ill explain a little.
nissan uses black silicone to seal the lights, and they use a HUGE bead of it, that is super-inaccessable. silicone is basically impervious to ANYthing. i contemplated all the ways to get it apart, but realized that even if i got the bead apart, putting it back together would be horrible with all the old silicone. so! i broke out the dremel and basically cut the entire housing from the lens. the thing is, i had to cut behind the sealing point. it took a few hours of precise dremel work, but it eventually popped open easily. sanded the chrome and painted it with flat krylon. putting it back together isnt too bad, just set the pieces back together, and seal the gap back up with black silicone sealant.
its not really a simple procedure by any means, but hey, modding is hard right???
