Headlight wont work
Adam_11
Car: 91 240sx
My car was in a wreck when i bought it so i purchased a whole new front end and now the drivers side headlight wont work... we checked to see if there is power and there is power but i believe that its not grounded... so how should i go about fixing this buy a whole new wiring unit? or try to manually ground it??
NISTECH
wiggle your head light switch while turning it on and off and see if you can get the light to illuminate, Bad head light switches on nissans are pretty common around those years.
Adam_11
Car: 91 240sx
thanks i'll try that.... but if thats not the problem i believe taht i have to manually ground the headlight.
NISTECH
if it is a switch heres a link to a fairly priced one, and its factory.
Adam_11
Car: 91 240sx
I dont see the link
NISTECH
DOH!! sorry about that
here you go.
http://www.trademotion.com/par...gid=1
Adam_11
Car: 91 240sx
thanks one more question u might laugh but i have a swapped KA with about 60k on it and i was wondering what oil i should use i need to change it... it sat all winter
NISTECH
I always use valvoline 5-30 in everything I own and have never had a problem.
Adam_11
Car: 91 240sx
hey i went to that link and it had no pic.... and i was wonderin if you knew a site that has a clip for the headlight motor the body shop i went to cut it off of mine... so i need the clip that comes from the car
NISTECH
I am not sure I know what clip your talking about?
Adam_11
Car: 91 240sx
the clip that the headlight motor clips into to make it go up and down... the one from the car is cut off.... does neone sale one???
NISTECH
I am sure they do, I looked at a 93's pop ups trying to figure out what your talking about and wasnt sure. you got a cam you can take a picture with?
Adam_11
Car: 91 240sx
i'll try but its just the plug i should say..... that the motor from the headlight plugs into the one from the car that makes the headlight motor go up and down
NISTECH
OOOH you mean the electrical connector. I dont believe that is available seperately you may have to cut one from a harness at the wreckin yard.
Adam_11
Car: 91 240sx
haha thanks and sorry for the confusion
Adam_11
Car: 91 240sx
u think if i got the sleep eye conversion that it would work??? even tho that motor dont work???
NISTECH
I think your head light switch is jacked up and not supplying a ground. So I dont think it will work een if you do the half up light setup.
Adam_11
Car: 91 240sx
sleepy eye conversion wont help my motor if its broken??? not the headlight im just talkin bout gettin the headlights to go up and down
NISTECH
so both the lights illuminate?
Adam_11
Car: 91 240sx
Ok.... sorry nistech im prob confusing u alot the passenger headlight works... but the motor doesn't go up and down because of the cut plug.... and my drivers side headlight doesn't light up but the motor works.... but the wire running from the car has power... its a three prong thing the top has power but the other two i think are grounds.... so ima ground that and see if it works i was just wondering if i got the sleep eye conversion if it could make my pass. side headlight go up and down manually
NISTECH
the light not illuminating is likely a problem with the head light switch. I am not sure whats involved with the conversion so i cant say weather or not it will pop up or not. Try asking in 240 technical about that as many of them have done the conversion.
eliterit
Car: pignose
sorry for the hijack, but i have an s13 that was recently in a very minor fender bender and ever since my passenger light wont lightup, sometimes it will, sometimes it wont. I checked for power with a test light and it gives off about half the voltage of the driver side (3 prong connector, top one is power).
u think it's possible that my headlight switch is messed up as well?
or its another issue?
eliterit
Car: pignose
headlight switched fixed my problem too. thanks!
