headlight wiring help
chmercer
putting kouki s14 lights into a car with a zenki wiring harness. high beam is direct fit. low beam on zenki had 3 inputs, one ground, 1 low beam power, and 1 high beam power. kouki lows only have 1 power, 1 ground.
so the problem is, when i hook both power wires from the zenki harness to the kouki projector, it powers the high beam as well, which i dont want. but i have to have that wire getting power from the low beams, or else it will not power the low beam when the high beam is on.
i can disconnect this wire, making only the low beam come on when switched to low, only the high beam come on when switched to high, but id prefer to have full functionality.
there has to be a way to do this without buying a relay? so many people have done this converison sombody has to know what to do.
