I've tried adjusting the motors to no avail. They fight with me as I try and adjust them and if I disconnect them and adjust them, when I plug them back in, they go right back into the one up, one down position.Xdisaster240sX wrote:Try to adjust the motors with a screwdriver.
Ghost518 wrote:This happened to my coupe
What i did.
put key in ignition. turn to on postion (dont start....can if you want)(or just skip this step)press the flip up button. take the cover off the manuel knob and turn. till both are the same. press the flip up button once or twice.
if still doing it. press the flip up button. disconnect battery and try^^. then plug the battery back in. it should be pretty straight forward and easy to fix.
Or you have a wiring problem
