Larz »
https://forums.nicoclub.com/larz-u216291.html
Fri Aug 09, 2013 10:47 am
Sorry to hear that is happening.
While I was at the dealer yesterday getting the rest of my fluids changed out, I asked my service guy about this. He had a tech come out and that tech told me that the headlamp is a sealed unit with no vents and if condensation is getting inside, it has to have a fault somewhere along the seal or a crack along the seal or elsewhere. He said the fault may not be visible, and it may not be large enough to allow water to pass inside, but it is enough of a fault to allow exchange of air and moisture to pass through.
He suggested putting a plastic adhesive or plastic-friendly sealant along the entire edge of the headlamp unit where the back and front of the unit is attached to see if that might cover the location of the leak.
Of course that requires removing the headlamp unit which, knowing Infiniti, probably requires removing god-knows-what other parts before you can get at the headlanmp unit. (that last bit was me, not the tech talking)
Best of luck and let us know how it turns out.
