jltibbs wrote:the manual will tell you to see the dealer. i would personally like to see your halogen low beam when you get it out. i have had a few customers recently argue that the low beam on their 04+ max was not HID. i was unser the impression that as of late 01 every max came stock with HIDs. even the dealership says so.
Maximas only had HID starting in '02.
HID was standard from 02-03.
When the 6th gens arrived, in '04, HID was optional.
I don't know if HID is still optional on the 6th gens, but it very well likely could be.
As for the headlights, if you have HID already, then it's Bi-Xenon (IIRC), and like jltibbs said, you'll need a D2S bulb (but only if you want to change color). Remember that the higher up you go in the K scale, the less light the bulbs put out.
I'm not familiar with the 6th gen halogen headlights, but I was under the impression that the low-beams were simply single filament bulbs. If that is indeed the case, then all you'd need is a single xenon "kit."
