headlight
sneekerbuddy
Car: 1992 infinti q45
how to fix a blown headlight on 92 infiniti q45
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Define "blown" please.
sneekerbuddy
l guess i'm just figuring it's blown. really all i know is that it is no longer working. but i still have both brights
Q451990
Have you changed the bulb? If not, that's the first thing to try. If you have your owner's manual, then the instructions are in there. If not here's the quick version:
Take the plastic cover off behind the headlight... they are held in place with some plastic retainers with philips head plastic screws in the middle. Half of them will probably break as you take them out. Then you'll have access to the area behind the headlamp assembly. Unplug the connector, making sure to catch the little rubber gasket if it tries to fall out. Then turn the bulb and pull it out. Put the new one in without touching the blub - the oil on your hands can cause it to burn out early or even explode if you touch it.
Good luck!
Heath
