Headlight sealing
Ill give u a head start
Car: 1993 Nissan 300zx Twin Turbo
After a rainy day my driverside headlight has some water residue inside it so it has a soggy look. The other side looks normal. Whats the problem
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
Your seal around the glass is broken/bad. The only way you will be able to fix it is to take your headlight out (~2 hour job), heat up the seal around the glass with a heat gun, take the glass off and reseal it.
dam sounds like a pain in the ***. ill leave it the way it is until some other work is needed in that area.thnx
