ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Sat Mar 05, 2005 5:00 pm
Its much easier to take the headlight housing out unless you have tiny hands and can somehow fit through all the other crap in the front.
There is a small screw that holes the corner lights. Once you take the corner lights out you will see two nuts. There are two bolts on the right side of the headlights as well. For easier access remove the grille. The grille just pops off after you remove two clips holding it. Now once the grille is off just take off all the bolts and nuts (4) and it comes right out.
