Headlight removal s14
Incubusfu
Car: music,sleep,cars
I need a crash coarse in how to remove my 95 240 headlights. Are they straight bolt on and is there anything i might break or mess up?
cory2081
Car: '07 Nissan 350Z
They are straight bolt on. You have to remove the grill, 2 bolts in the center, the 1 screw near the fender that holds the corner light on, pull the corner light off (it kinda snaps into the headlight) then there is another bolt on the side behind the corner light. Not very hard at all.
Incubusfu
k thanks
JimmyJames1
Do the Kouki headlights cornerlights come off like the Zenkis? I've got the 2 bolts behind the grill off and the one screw near the fender holding the corner light on, but my cornerlight doesn't want to snap out. I don't want to force it and break something. Is there another screw there that I can't find for Koukis, or should I just apply some more force?
KFL
Car: S14
JimmyJames1 wrote:Do the Kouki headlights cornerlights come off like the Zenkis? I've got the 2 bolts behind the grill off and the one screw near the fender holding the corner light on, but my cornerlight doesn't want to snap out. I don't want to force it and break something. Is there another screw there that I can't find for Koukis, or should I just apply some more force?
2 bolts on the left and 2 on the right of the headlights, You have to remove the corner light 1 screw holding it down, pull at angle that will expose 2 other bolts to remove. If you have that done apply more force as the cornerlight has a plastic socket type ball that holds it in place as you'll see.
