71-521 »
https://forums.nicoclub.com/71-521-u110104.html
Wed Dec 31, 1969 5:00 pm
the alt won't get you brighter lights by itself...
just gives the system more amps to draw from...
bypassing the switch with a relay like this should brighten up the lights a bit due to the resistance of the old wire and the switch...
I just put in an Amp meter to see exactly how much power I was using...
even with everything on, lights, wipers, heater, brake lights, no sterio installed..
I was drawing less than 20 amps...
I'm going to see what the 150 watt lights will draw when I get them from Oz...
then I'll decide on whether or not to get a new Alt...
