Headlight relay in Z31
A home for 1983–1989 300ZX owners!
EquinoxNW
Car: 1985 300ZX Turbo
My 1985 300zx Turbo has no high beams, and good fuses, so I suspected a relay - but it doesn't appear there is one in the cluster under the hood. Does anyone know where it is? Otherwise I'm guessing the switch, but high beam clicks into place OK [but gives darkness]
--Oregon John
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
headlight switch, it normally effects low beams but might well be the cause of you issue.
EquinoxNW
Thanks-
I have discovered which color wires from the HL switch control high beam, so may check them if I can get into those connectors!
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
There is no headlight relay.
The common solution for headlight problems is to replace or clean the switch.
wilz87t
Car: 1987 300zx turbo
1990 300zx twin turbo
As usual, Az bum giving "BUM" data. No headlamp relay? So, what the hell is the black 5 prong relay in the hidden compartment (next to fusible links/little plastic cover/battery HAS to be removed) that energizes when the low beam is switched on? I know this is a old thread, but man...perhaps that Arizona sun is getting to you. Can't think BEYOND the FSM. sheesh!
evildky
06 Nissan 350Z GT
headlamp motor relay
wilz87t
evildky wrote:headlamp motor relay
Wrong one?. However, schematic on page EL-35 shows "Headlamp Relay" , so , ofcourse, there IS one....
wilz87t
Actually..the black one in the hidden compartment is the "uphold relay". FSM EL-191/ 64E = Headlamp Relay.
Return to “300ZX (Z31) Forum”
