headlight question urgent!
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
StMichael
Car: 2005 Infiniti G35 coupe
Ok I have a body shop replacing my 2005 reflector headlights with a set of 2006-2007 projector head lights. The new headlight assembly has all of the original headlights, so from what I have read is all I need to do is take my ballast of my 05 and transfer to the new see. I got them transfered, but where does the yellow ground wire supposed to go??? Thanks mike
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
StMichael wrote:Ok I have a body shop replacing my 2005 reflector headlights with a set of 2006-2007 projector head lights. The new headlight assembly has all of the original headlights, so from what I have read is all I need to do is take my ballast of my 05 and transfer to the new see. I got them transfered, but where does the yellow ground wire supposed to go??? Thanks mike
i would def look at the FSM. for those year model lights, the only reference to a yellow wire was the one that goes to the combination switch. check the FSMs in the FAQ and the lightinh system is the one labeled LT.
good luck.
joe603
Car: 2014 Durango R/T
FSM link in my sig
Return to “G35 and G37 Interior, Exterior and Audio”
