Headlight question
tonymontana240
Hey, I just had a question. I have a 1992 240SX. What I wanted to do was adjust the headlights to give it the 2/3 popup effect or as others call it the "sleepy eyed" look. I read in the FAQ that it is suggested to get fog lights installed if you're planning on disconnecting the headlight motor while driving around at night. Now my question is, if I get the fog lights and install them inside the duct on the front bumper, how do I wire them so that they turn on with the lights? And can anyone explain exactly where the motor needs to be disconnected at. Any help or suggestions are welcome.
hotshot240sx
Car: my 240sx
i have the remedy man...you need a switch and sum extra wires..make shure the switch has three terminals on it...first locate the green wire behing the head lamp flip button...its on the left on top of thge cruise controll buttons...remove the cluster to see it...by dropping the steering wheel and hitting a few screws...tap into that green wire...splice it to the middle terminal of the switch...then run leads to the battery positive and negative...flip the lights up...then hit the switch to lower em by levels...thats what i did...it sounds confusing...but its really very simple...
hotshot240sx
Car: my 240sx
and you dont need to disconnect the motor...trust meeh!
