headlight question
Stone Cold
One of my HLights went out last night. WHen I pulled it and bought another- it was a highbeam light. But they are the ones on normally. So which ones are supposed to be the low beam and which the high beam?I ask becuase, when highbeams are turned on-- they just light up the road right infront of the car. Nothing further down the road.....
driverdriver
Car: NICO's longtime resident Canuck!!!
Here you go:
zerothread/217496
Make sure whatever you get is a 55w bulb.
Stone Cold
So which light in the headlight setup- the inner or the outer is the low beam? I took a 9005 out of the socket. I think the ones in the outer light are 9006? Any clues? I get flashed for highbeams all the time. But only 2 are on. When I turn on the highbeams- all 4 come on. But it doesn't get brighter down the road- just infront of the car.
yodawill2000
Car: 94 Infiniti J30
The high beams need to be aimed.the outer lights are the low's
fogged306
Car: 1997 j30
Outers are your low beam and the bulb number is 9006.Inners are your hi beam and the bulb number is 9005.
http://www.sylvania.com/Consum...s.htm
Heres another link to a bulb replacement guide for J30's
