Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Dec 16, 2014 2:20 pm
Florida has a similar law as well - "lights ON when raining". I have DRLs in the front that activate when the engine is switched on and I set my light stick to use parking lamps so the tail lights are also lighted in rain.
I have found no info about rigging the headlamps to light when the auto wipers switch on. I also recommend DRLs. Even if you have to manually turn your low beams on, the car won't let you forget to switch them back off and even if you do forget, the car will switch them off after a few minutes even when not in auto mode. You can find a few threads about how to install them on here. I believe there is a DYI in the FAQ thread as well.
