Headlight Problem
Homeless41
Car: 1990 Infiniti Q45
Hello All,
I'm new to the forum and have found some good information, but haven't found anything for a specific problem that I have. My uncle recently gave me his 1990 Q45 that is in great condition. It only has 70,000 miles on it and still has everything that came with it when he drove it off the lot, down to the Bose demonstration cassette and spare keys still in the case. The problem is that the headlights do not work. Everything else on the car works, the running lights, brake lights, turn signals, and everything else. I checked the usual suspects including the fuses and bulbs. My uncle thought the problem was with the switch on the steering column, so I took apart the dash and pulled the headlight switch out. I tested the switch with an Ohmmeter and it is working fine. The headlights, as well as the brights do not work, and I was wondering if there is an easy way to test the other components of the system, or if there is a common problem that causes this. Thanks.
-Clint
Q451990
:welcome: to NICO Clint!
That sounds like an amazing score on a low mileage Q... I'm jealous! You should post pictures!
Does your dash show "headlight out" on the display? If not I would suspect the headlight sensor. I've never seen one fail before, but when the sensor for the brake lights fail, that's what happens... they just stop working.
Do you have the factory service manual? It should be in the trunk, rear armrest compartment, or compartment between the speakers on the rear deck. If you don't have a copy, there's an online version for a 1991 here - http://www.nicoclub.com/fsm/
EL-150 and EL-151 show the location of the headlight relay pack and headlight sensor.
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If the headlights are a problem, I have a spare set.
Probably just a relay.
