Headlight problem
kainoa
When i bought my car the headlight doesnt go up or down so i thought it was the headlight motor, i had a little time to look at it today and found this(picture below) could this be my problem or something else? any help would be aprreciated.
solaris22
uhh yeah
kainoa
do you know what that part called or the part number for them?
quiksilvia
Car: 95 s14 se
well they are relays, and u may want to see which if any are bad before u go and spend $, its a common possibility one of those are bad. search for headlight relay and there is thread that tells how u should test them
NISTECH
whats there to test? 2 of the relays are missing and in their place is some homemade wiring set up using both the fog relay port and the head light retractors.
kainoa
yeah i noticed that homemade relay rigged in there i dont know whats it for
NISTECH
Rip that sh** out of there and go down to your local nissan to get the correct relay's and stick those in. see what happens from there.
