propagandhi »
https://forums.nicoclub.com/propagandhi-u128782.html
Mon Mar 16, 2009 11:05 am
funny, I was searching for this today, I have this same problem with my 1990 S13.
Only the right (passenger) works on low beam and on high beam, only the left (driver) works. Sometimes when the brights are on, or when the switch is pulled back towards the steering wheel (to flash high beams), both will work. I think my problem is in the switch itself. When the switch is between the low beams and the flash high beam position (wish I knew a better term for this) they both will work, but since that isn't a proper position ones goes off again.
AutoZone sells the switch for around $50, or try a junkyard.
I'll let you know if I fix it soon.
Anybody else have this problem?
Bump.
