Headlight Problem
skyline3489
Car: 95 Kouki Conversion 240sx (Sold)
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
16 Challenger Hellcat
Ok so i got a problem with my headlights. one headlight works and the other doesn't (passenger Side). i thought it was just the bulb but it wasn't. it looked at the wires and it looked ok, so a fuse probably? help plz thnks
ZX88
Car: s13
skyline3489 wrote:Ok so i got a problem with my headlights. one headlight works and the other doesn't (passenger Side). i thought it was just the bulb but it wasn't. it looked at the wires and it looked ok, so a fuse probably? help plz thnks
check the combination switch i have a write up on another forum that starts with a Z but i dont think i can post the link.
Fla240sx
mine ran into that problem, simple solution is to run power from the driver light to the passenger light from the wiring harness going to the drivers light... I don't know what the real fix to this situation is, but that will work. I'll check into this combination thing for myself... cause I'd really rather have it hooked up like the way it came from the factory, but this keeps me from getting tickets
xMordecaix988
Car: 1993 240sx SR20DET
1995 S14 KA24DE
mine was the same, all my fuses and wires were ok. It turned out to be the multifunction switch, the left stock on the steering column.
Romulox
Car: '89 240SX Coupe+RB20DET
instead of posting a new topic i will just ask my headlight question here. my headlights flip up fine but when they flip down the driver side light shakes and studders like somethings gonna break.any idea what could be wrong?
vancouverbc
Car: 1991 240sx
check tutorial link in my signature fore headlight. I would just replace the switch if you can get at reasonable price. it is very hard to troubleshoot.
jerryk
Car: 1990 240SX
Passenger side Hi beam does not work. It is not the fuse or the bulb could it be the multifunction switch? Where on the steering column is it located? I have another parts car I can take it off. Dash Hi beam indicator does not work.
my40
Car: 91 240sx
drivers side Hi beam does not work anyone find a solution to the problem. could it be the combination switch? its not the fuses or the wires all checked fine. Just don't have 50 bucks for the switch.
thanks
chris
Hijacker
Car: '92 240sx Convertible
'94 F-150
If it's not a fuse and your wiring is done right, the only option left is the switch. If you want to eliminate the switch as a possible problem, I would check for continuity on the circuit starting at the steering column plug. If you have continuity, then you have a bad switch.
my40
Car: 91 240sx
I checked the continuity, and as expected it was the switch but the good thing is I found someone that has the switch for cheap. Thanks for the help hijacker I owe you one.
