headlight problem s14
rotaryland
Car: s14 zenki
the screw that adjust the bulb in the headlight isnt moving the bulb nomore anyone know how to adjust it?
s13sr20chris
you could try taking the adjustment mechanism apart or something. usually if you run out of adjustment it means you had to adjust too far and something is bent.
rotaryland
Car: s14 zenki
its the s14 headlight so i have to take the headlight apart?
s13sr20chris
to be clear i have not had this issue but i believe the adjuster is external?if so i would pull it off and make sure it works properly. sometimes they have plastic gears and its possible that they stripped out.
Dearths240sx
Car: 1996 Nissan 240sx
Sorry to bring up an old post, but I have the same problem and I still haven't found the solution. Somebody help.
