headlight problem on 02 q
cablemn
right headlight goes on only after i turn the switch on and off a couple times then it shuts down again. From previous posts and searching i believe it to be the HID control unit for the passenger side light. It seems hard to get to. If there is some easy way to fix this problem let me in on it. From what i understand the front bumper needs to be removed. Does anyone know how much this part should cost? Dealer quoted me $270 just for the bulb! Thats insane. Help would be appreciated thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
For OEM we use Joe and his crew at IoS.
http://www.infinitipartsusa.com
Have you tried switching ballasts?
Modified by maxnix at 9:17 AM 1/27/2008
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
cablemn wrote:right headlight goes on only after i turn the switch on and off a couple times then it shuts down again. From previous posts and searching i believe it to be the HID control unit for the passenger side light. It seems hard to get to. If there is some easy way to fix this problem let me in on it. From what i understand the front bumper needs to be removed. Does anyone know how much this part should cost? Dealer quoted me $270 just for the bulb! Thats insane. Help would be appreciated thanks.
Known problem on these cars, you can buy a used ballast and/or bulb, its one or the other. Do not buy the bulb from the dealer, look online and you'll find plenty, the ballast might be found on car-part.com
Good luck!!
cablemn
I looked up ballast on the parts site and nothing came up. Does it go by another name? Does anyone know the part number?
Q451990
I would swap the ballasts side to side (assuming they're the same) and see if the problem follows the ballast. If it stays on the right side, I would look toward the bulb. check out your FSM at http://www.nicoclub.com/FSM/Q45
Heath
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
Agree I woud do that to if needed. ^^^
Alter-ego
Car: Infiniti Q45 Premium
Bump
Q451990 wrote:I would swap the ballasts side to side (assuming they're the same) and see if the problem follows the ballast. If it stays on the right side, I would look toward the bulb. check out your FSM at http://www.nicoclub.com/FSM/Q45
Heath
Bump! Good Advice!
bullittandy
cablemn wrote:I looked up ballast on the parts site and nothing came up. Does it go by another name? Does anyone know the part number?
Look up headlight assembly and you'll find lots of them, look for an ad that says "ballast only", wrecked cars often have broken housings but the ballast should be safe.
