james t kirk »
https://forums.nicoclub.com/james-t-kirk-u69152.html
Thu Jun 10, 2010 4:55 pm
Ok, so first off, I'm in Canada - so we have manditory Daytime Running Lights. (A damn good idea by the way.)
But one of my DTRL is not working. (So replace the bulb you say, well, not so fast.....)
You see, the DTRL are simply the fog lights (which come on during the day automatically). When the Head Lights are manually switched on, the Fog LIghts function as normal. So if the bulb were burnt out, this should not be the case
And also strangely, the one DTRL that does work (the left one) is powering up the high beam elemant. (So this is scewed up too.)
So in other words, when I should be running with both DTRL, I only have the left luminaire illuminating and it is the HIgh Beam.
Headlights work as normal
Auto works as normal
HIgh Beams work as normal
Fog Lights work as normal.
Just the DTRL (right) is dark and the left one is the High Beam.
Any ideas?
Relay Module? If so, where is it located? I can hear the relay tripping around the glove box when I hit the High Beams.
Any testing ideas or tips would be appreciated.
By the way, my car is a 2005 G35x. (I recently had a front marker bulb out and the dealer noticed it when I was in for an oil change - they wanted $37.00 to replace it. I almost choked when I heard that. Took 2 seconds (seriously) to swap out the bulb.)
