headlight only works on highbeem s13
J0SHYee
Car: 1991 240sx
2001 I30
so my passanger side headlight has been out for quite sometime and only worked on highbeems. So i thought i just had to get a bew headlight which i did and replaced. but when i turn the headlights on it still wouldnt turn on. my driver side one works perfectly but the pass side still only works on highbeem. Any help?
sl240
Car: s13
i had the same problem. drove me nuts!!!! i finally gave up on trying to figure it out. i fixed mine by running a new power wire from the driver side to the passenger side. it is kinda rigging it but at least it works.
J0SHYee
Car: 1991 240sx
2001 I30
really i think im about to do it can you expain like a little in detail how you did it ?
torque87
Car: 98 240SX SE Black
lol, I am having the exact same problem. I'll be watching this thread for some more ideas.
sl240
Car: s13
ok guys here are the details of repair: i used 12 or 14 gauge primary wire.on the driver side headlight plug there are three wires the red wire with the white stripe (the middle one). I soldered new wire about 6-8 inches from plug and ran wire across to passenger side. the red wire with white stripe i cut about 6-8 inches away from the plug that goes into the fender leaving the headlight plug wire long and leaving some wire on the other plug side that goes to the fender. now solder the new wire to the red wire with the white stripe that goes to the headlight plug on the passengers side. LET THERE BE LIGHT
torque87
K, I'll give this a shot till I can figure out the real problem. I've been pulled over twice already, and really can't avoid driving at night.
MastaYu
Car: 92 Nissan 240SX SE HB
I've got the same problem but on the driver's side
junjun0134x
Car: 93 Nissan 240sx
lol i had that same problem with my passenger side light only it wouldnt work at all...after a while of trying to figure out why i just got tired and rigged it the same way
ZX88
Car: s13
its either a blown fuse or the combination switch check it out i had the same problem and it was my combo switch. heres my write up that might help you out.
http://zilvia.net/f/tech-talk/....html
adrianfromthecastle
Car: 1992 Nissan 240sx
I'm almost 110% possitive that its your headlight switch. Just get a new switch. I had the same problem, went to the junkyard and got a used one that was in better condition than what I had (yeah, junkyard is a risk too)
240_SeX
Car: 1992 240SX SE
thanks, im off to take the combo switch out of my parts car...
MastaYu
awesome i will check into that switch
240_SeX
Car: 1992 240SX SE
Install complete, works now, thanks guys only took about 15 mins
MastaYu
you got that switch fast
240_SeX
Car: 1992 240SX SE
Thats whats great about a parts car
on a less joyfull note....
I HATE these STUPID F'N sealed beamsI put the switch in, all is fine. Go for a ride and thr goddamn headlight blows...... Hella H4 conversion lamps = in the mail.
torque87
ZX88 wrote:its either a blown fuse or the combination switch check it out i had the same problem and it was my combo switch. heres my write up that might help you out.
yeah, i tried that, didn't work. I really don't wanna rig it but i'm totally out of ideas.
Lumos
Wow, I had that problem also. Fixed it by leaving my high beams on for the next year.
torque87
lol, maybe i'll just aim my highbeams way down and hope cops don't notice.
