4cefed »
https://forums.nicoclub.com/4cefed-u1486.html
Wed Jun 17, 2009 4:32 am
Headlight switch.
They get carbon build-up and the contacts don't make contact very well. New ones are about $70 so I've had to clean out mine like twice now. There have to be like 100 threads on this, so try searching for it.
In a nutshell, pull the switch unit out of the steering column and carefully break off the white plastic cover. Try and get it off so you can get it back on later. Get some small strips of sand paper and put them in between the contacts, close them, and pull the sandpaper out. Do this for both top and bottom contact several times. Your lights should work for another couple months at least.
