SunLitSandMax00SE wrote:looks like a good mod
maybe some pix of the car itself for comparison
also, the lowering of the springs is 1.6 in the front...did that much of a drop affect the headlights that much because I am about to drop mine to a similar drop....I'm wondering if others have encountered your problem as well
I don't think you will have the same problem as I did due to you owning a M35 and I own a M45. The weight difference of the engine is what cause my M's front to lower more than the rear. It was enough to make the headlights aim down about 15 - 20 degrees if not more on the driver's side and maybe 5-10 degrees on the passenger side even at maximum height adjustments. My highbeams hit the trees. It sucks and it dangerous so I am getting the headlight mod instead of spending $2200 on Coilovers to get the drop even. I like the drop, 1 finger gap in the front and 1.5 finger gap in the back.
Crappy thing is that now, when I am driving across intersections, I cannot see the other side until I am at least 1/3 or 1/2 of the way into it.
I have asked across the board but it seems that there are a lot of M35 on Eibach with no problems. M45 owners are on the Epsilar springs or coils and don't have the problem either.
I am at a loss, but it will be money well spent and make the M a bit more unique than other's out there.
I only plan to do a few mods to the M since my last car had everything I could get on it. It was a money pit and I only sold it for $6000.00.
Things I plan to do or have done are:
Nav Hack (Done)Lower (Done) Possibly to JICs laterTint (In the Spring)Headlight Retrofit (Schedule for 18th, 19th of this month)Foglight Retrofit (Scheduled for 18th, 19th of this month)Shift Mod (Will do soon)
If someone ever comes out with a Ypipe for our car, I will also do that. Other than that, I want to keep her as quiet as possible. Too many cops in VA that find any reason to pull you over.
In my supercharged Max, I was pulled over at least 2-3 times a week for:
-No front tag-Exhaust-Suspension-Tint
All none moving violations but after I added up all the tickets I paid, I could have bought my M sooner!
