headlight leveling
KyleP
Car: 1999 q45t
I have a 99 q45 touring and one of my headlights isn't leveling. Have any of you ran into this, just wondering where to start?
Thanks, Kyle
Q451990
Unfortunately, I don't have much more for you than a link to the service manual...
www.nicoclub.com/FSM/
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
When you say leveling, do you mean active leveling?
These headlights don't really have the ability to "self-level," when they are referred to as "leveling," I believe that refers to the fact that there is a switch by your left knee that allows you to change the level as you see fit.
Are you saying this switch isn't working? Make sure you're pointed at a close wall to test, it's not a huge difference.
If not, check fuses with a multimeter for continuity, easiest and fastest way.
KyleP
Car: 1999 q45t
the switch is what I am referring to. Only the left light moves. The switch works.
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
Weird - I believe it's one fuse for both, so it must be a wiring issue. Start wiggling!
KyleP
Car: 1999 q45t
that was the culprit! I used some contact cleaner and its working perfectly now. Thanks for the help guys!
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
Glad to hear it Kyle. Happy Thanksgiving.
