onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Jul 11, 2005 2:37 pm
To get the lens off the housing, you will need to "cook" your headlights.
Remove any lightbulbs, harnesses, etc.
Preheat oven to about 250 degrees (I'm pretty sure it was only 250 degrees, just enough to melt the glue)
Then let the lights sit in there for about 5-10 minutes (if I remember correctly)
After that, you take them out and you can start prying the edges off. Be careful because you can damage teh lens. This method (used for retrofitting) should retain the most goo.
Install is reverse.
It's often easier/better to just buy new lights, haha.
