Headlight lens cover replacement - worth it?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
ThomasForelle
Car: Infiniti EX35 AWD Journey 2008
6/16/22 == 115,500 miles
https://www.ebay.com/itm/203400041262. This is a link to a lens cover replacement. Less than half the cost of headlight
My 2008 EX35 has a yellowed lens on passenger side. I have tried several polishes, but none really restore to clear. The tasty deer I hit on my way to go deer hunting in WI took out my drivers, so I’ve a bright new one that makes the other one look especially bad. Rather that the 550 or so for a new headlight, I wonder if anyone has tried this solution? Just the lens? Requires some effort apparently with a heat gun to remove and replace the lens. Any input would be appreciated.
Dzionassi
Car: 2017 Infiniti QX50
I do not recommend It. There were reports on bad headlight covers from China.
jethbon
Car: 2014 Nissan Pathfinder
What he said. Buying Chinese-made parts is a hit or miss.
ThomasForelle
Thanks y'all. I'll forgo the cover replacement. Anyone have success with restoring a lens to satisfactory condition? Seems like my lens has micro fractures through out.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
ThomasForelle wrote:
Tue May 25, 2021 10:28 am
Hazing is one thing, even if it's inside you can bake-off the lens and buff it out. Spider-webbing is a different story, that's pretty much fatal.
ThomasForelle
Anyone have the best idea on how to restore a lens? I could deal with the spider-webbing, but the dinge I could like to clear off. Products? Techniques?
Johnnydangerus
Car: 2010 Infiniti EX35 Journey AWD premium package tech package. Obsidian black; Tan. 18" stk Michilin Primacy a/s. Remote start.
I tried cerakote and turned out ok but best result is used new to match driver's side.
paulstaf
Car: 2008 Infiniti EX35
Someone posted this link elsewhere. About $430 per headlight, better than other higher cost options:
https://amazon.com/AKKON-2008-2012-2014 ... 0B9HVKCJ2/
jackie8z
Car: 2011 Infiniti EX35
2008 VW Touareg
I just purchased left and right with glue from China, total around $30 from Taobao and it is still on the ocean freight.
Mine was crazing badly and polish won't help anymore.
The cover is not the only problem, if you open up your projector you may find out the reflector is bad. I also purchased some bi beam projectors SANVI 2.5' 3' and 1.5' and Q70 mount to try to fix the entire headlight unit. Mine is without AFS so the inside mount is very strange. It already cost me $500 total, still waiting for the parts.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
