Headlight Issue
ottawa_ca
Car: 200 Maxima SE
I have a 2008 Maxima SE with a headlight issue. The headlight on the left side comes on when starting the car however within 20 seconds it goes out. Could this be the igniter/ballast controller? I have been reading a lot on the internet that the controllers burn out often. The headlights are Xenon. Is there any quick test to determine if it the controller?
Thanks
Paul
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
The quickest way to check is process of elimination. Swap the ballast. If the problem persists on the same side, it's the bulb (more than likely). If its goes to the other side, then it's the ballast. I guess the other way you can try it is to swap bulbs. Pretty much same scenario.
Welcome to NICOclub.
