headlight issue
vincent.wallen
Car: 1990 Nissan 240sx s13 hb stock ka24e
hello i just bought a 1990 240sx s13... my issue is that the light switch on the steering column that is supposed to flip up the lights and turn them on... only turns them on... so i have to push the button to flip them on and then turn them on on the column... i was wondering if there is a seprate relay system for the 2 switches... its not that big of a problem... its just annoying... thanks in advance...
Vincent
vincent.wallen
bump
vincent.wallen
bump!
S13Joe
Car: 92 Coupe
then i guess you shouldnt have bought a 240... thats how they all are pal.
vincent.wallen
o ok... so they come like that?.. i was just wondering... sorry i dint know the fine details of the car...
vincent
tercel drifter
Car: sr20det s13
on my car the lever on the steering colum flips them up and turns the light on
and the button beside teh steering wheel just flips them up for looks i guess if u wanted them up during the day without light
vincent.wallen
tercel drifter wrote:on my car the lever on the steering colum flips them up and turns the light on
o ok... thats what i thought... do you know if there is a different electrical system that runs the two switches? im looking for something like a relay that has gone out.. thanks...;
vincent
vincent.wallen
bump
ricebike
2002 Quest
2005 Altima
that doesn't sound right w/ your system...
i think the previous owner tried to do one of the many ways of a mod called "sleepy eyes"
when i turn on my headlights using the column switch stalk... the headlights pop up& when i turn the lights fully off, they go back down
the headlight button on the dash is for keeping the headlights UP during the winter months so you won't have frozen shut headlight eye lids when you need to drive in the winter...
so yea, check to see if there were signs of doing that "sleepy eye mod"
vincent.wallen
ricebike wrote:that doesn't sound right w/ your system...
alright... great... thanks...
vincent
speed breeder
Car: Nissan 200sx S13, Toyota Hilux 2001 2.7 D/C, VW Polo
Hey Vincent, mine also does this... My car however used to be able to lift the eyes and turn on the lights using the stalk...
Must be a relay... I haven't found it... too lazy to look in the manual + our weather never gets so cold, so not a real issue...
I think it could be the wiring in the stalk that has two seperate signals for lights on and up and the one is maybe "dry" or not making contact...
You can perhaps remove the stalk and clean the connections... which also sometimes fixup rear tail light and dash light issues.
Z
vincent.wallen
i was talking to my dad about it and he was thinking that both buttons should run the same relay to lift the lights and that it might me in the stalk like you say... right now im trying to get the car running... no compression in any of the cylinders... =[... but then ill take the stalk off and spray the contacts and see if that fixes... and thanks for the help... ill also look in the manual and see if i can see whats up there... lol... thanks again..
vincent
