msjbhall »
https://forums.nicoclub.com/msjbhall-u272600.html
Tue May 02, 2017 10:44 pm
I don't know if this helps, because I have a 2002 Q45, but I had what sounds like a similar problem with my headlight(s) - one at a time. For a few weeks before my low beam quit, it was working intermittently. The high beam works fine. I bought a D2S xenon HID bulb from Pep Boys $88, and it didn't work.
Then I went through the unbelievable misery of unbolting the grill and front bumper covers just to be able to pull the headlight assembly out to get to the ballast. Since the price of the bulb and ballast at the dealership was outrageous, I went to Amazon.com and found a thinner ballast that otherwise matched the features of the OEM part. (uxcell Car Headlight 35W HID Slim Ballast Black for 9005 9006 D2S Xenon Bulb) for about $12. It was so much slimmer that I decided to I just leave the old one where it was, cut off the old one's wire to the wiring harness, connected the new one to the harness, plugged it into the back of the headlight and it worked. The ballast came with a fitting to attach it to the vehicle, but I just let it lie in the area between the battery and the wall of the engine compartment. It has worked fine for 2 years now. Unfortunately, I realized too late that there are other bulbs seemingly the same for a fraction of the price on Amazon. I could have easily bought 2 for what I paid Pep Boys. Live and learn! Good luck to you.
