So, I have an 05 Titan and I'm having headlight issues. On low beam, the drivers side doesn't come on. On hi beam, both sides come on. I've checked the fuse in theIPDM and it looks good (for the driver side low beam). I haven't checked voltages on the bulb side because I don't have a multimeter. I was wondering if there was anything else I could check or even a wiring diagram that someone might have to help troubleshoot. Is it possible that the signal for each lamp splits right off the bat at the control on the steering column? If so, it could possibly mean that the switch is bad. Was thinking about doing some continuity checks on that too.
Any help would be greatly appreciated.
hubbysride
