Headlight Focus with Aftermarket HID's
Forum for the unique Murano, and official home of Nissan Murano Club!
DSK
Car: Murona SL AWD
Hello,
So i added HID's to my 2011 Morano and they are great but the focus on the divers side is so soft compared to the passengers side. The passengers side is soo focused I can see it contours hit the payment 15 ft out. The Drivers side is acting more like a fill light. I know where the adjusted is to raise and lower each light but they seem to be in alignment with each other, is there a way to focus them?? Thanks
Leo2005
Not sure which hid you got but most of the time you should get the almost the same focus from both headlights unless the car was in accident and headlight was not installed properly. You may wanna try LMZ led bulbs which you able to turn either vertically, horizontally or diagonally to adjust the focus the way you want. Other than that use adjuster and you may try unscrew the headlight and move it a little bit.
Return to “Murano Forum”
