Headlight film
Stu Pidasso
I have an '06 coupe. There is some film that has accumulated on the inside of the headlight lenses. Anyone know of a way to clean this out?
joe603
Car: 2014 Durango R/T
Are you sure it's on the inside? I'd try to use a plastic cleaner (Plasic X works well) before trying to take apart the headlights. You have to actually bake them in an oven to remove the lens from the assembly.
zozoka1212
Car: 08 Infiniti G35x
I'm with Joe. Most people who put film on it they put it outside. Try a heatgun and peel it off. If it is inside it is most likely paint. Why would somebody do that? Kind of defeats the purpose of the headlight.
Hope you can clean it.
Joey666Crack
Car: 06 G35 Coupe
I believe the OP might be referring to the cloudy headlight film, not a actual film put on intentionally/
Stu Pidasso
Bought some Meguiar's clear plastic cleaner. Worked great. The film ended up being on the outside, but windex wouldn't take it off. Looks like new now.
Tim30250
Car: 2009 G37 Journey Premium/Nav/Cargo Net!!! 2002 330Ci - Supercharged
That stuff does work very well. A lot of places are offering "headlight restoration" services now where they take your old opaque headlights and magically make them clear again. They're actually just doing the same thing you did and charging folks ~$50 for the simple procedure. Spending a few bucks for this cleaner and several minutes of time each year will keep headlights looking clear and new indefinitely.
joe603
Glad you got it fixed
