I'm having an issue with my 2015 Infiniti Q50 where there is a headlight error on my dashboard. All the lights and sensors are perfectly functional. The dealer said that it was a wiring issue and would charge me straight time for diagnostics, which I am not too keen on. An electrical shop checked all the wiring, said that everything is fine. Apparently, the dashboard light is being caused by the absence of an adaptive front-light sensor (AFS). The problem with that is my car is not equipped with an AFS. No DTC code is showing up on any scanner. Any thoughts on how to get rid of the warning on the dashboard?
Thanks!
