Q-lesshttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113Headlight disassembly - spring/gear fix adjusters on 94 Q45Tue Nov 02, 2004 8:54 am
Postby
Q-less »
https://forums.nicoclub.com/q-less-u12928.htmlTue Nov 02, 2004 8:54 am
I am ready to attempt to fix my headlights as I cannot adjust them correctly. I know someone on here has done it before and I believe they just reconnected some springs. Can that person or anyone who knows exactly what to do give me a step-by-step on the process. I used the search but could not find the info. I'll take pictures of my job and post them if I am successful.
P.S. -- Stupid thought, the headlights take 9005 + 9006 bulbs right...what would happen if you put 2 high beam bulbs in the headlights? What size bulb goes in the foglights?
Postby
maxnix »
https://forums.nicoclub.com/maxnix-u127.htmlTue Nov 02, 2004 10:49 am
CherryPoppinQ45 wrote:1.) Stupid thought, the headlights take 9005 + 9006 bulbs right...2.) what would happen if you put 2 high beam bulbs in the headlights? 3.) What size bulb goes in the foglights?
1.) 9003ST and 9005ST (for Silverstars)
2.) You wouldn't be able to connect the harness to the bulb, so you would have no low beams.
