Headlight delay...
groundhogday1976
Car: 2015 Altima 2.5 S
This morning when I was leaving for work, I turned on my headlights and the one on the passenger's side didn't come on. Then after a few seconds it came on. It did it last night and once more this morning. I'd just go ahead and replace the light, but the fact that it does come on after a few seconds makes me think there's another problem. What could it be?
NISTECH
the switch is pretty common to go bad an nissans in genral. usually due to poor contacts internally
Chris Mitchell
I am having the similar problem with my headlights on my 94 J30. Are you talking about the relay switch?
NISTECH
the switch you turn to turn the head lights on
groundhogday1976
I noticed it only happens on the low beam. High beam operates normal. I'm gonna replace the headlights this weekend. I've been looking for an excuse to get some Silverstars anyway. If that doesn't solve it I'll look into the switch.
Chris Mitchell
I just replaced the relay switch under the hood yesterday and this morning I had not problems with the headlights.
pstickne
My left headlight started acting funny (going up delayed or going down delayed). Then just a week or so later it (low-beam) died. I replaced the headlight (entire stock-replacement sealedbeam) and I have yet to experience the "lag" effect......sound like a feasible correlation?
ravenhawk021
Car: Skiing, My car
My low beam on the pasengers side will not come on. Was told by previous owner that if you turn the lights on and off repeatedly it'll come on. Checked the plug, the two contacts on each side were shorted together but I don't have any manuals or wiring diagrams to find out where. As far as I know there never was any kind of delay. I have changed the lights out also to no change. I also have a problem with the key release, when the wire is conected it won't release the key, makeing it very easy to steal. I would like any help I can get, I know nothing of cars.
NISTECH
switch
ravenhawk021
Car: Skiing, My car
Switch was checked by our resident electrical engineer. He says its good but how can I confirm or disprove this?
NISTECH
nissans burn up switches quite often. How did your resident elctrical engineer know which terminals would have contact at which points without a wiring diagram. the switch will close more then one or 2 circuits at a time.
ravenhawk021
Car: Skiing, My car
I think he just used proir experience. I wish I had been there to tell you for sure. He been in electronics longer than i,ve been alive, but that has always been working on and designing radar equipment not cars. So maybe he is wrong. My other coworker has gone to college for auto design and points to a switch or relay, but can't (or won't) say which or where with out a diagram.
jettstryker
headlight relay switch on the driver side near the firewall. easy fix.
ravenhawk021
Car: Skiing, My car
thanks guys I trouble shot it down to the switch like you said Nistech he must of assumed it wasn't the switch thanks agian for your help
