Headlight Bulbs
Big_Tone
Car: 2011 Infiniti M56x (White w Java interior; Tech Pkg)
PPE Headers; HPS Intake
Custom 2 1/4” exhaust with Jones Exhaust X-Pipe
Infiniti Sport mufflers
Hey gang. Got a question about bulbs...
I had my high/low beams changed over to LEDs recently and really like it, but I noticed one of the other bulbs (park/auxiliary/I don't know what it's called) bulbs that comes on before turning on the headlights is out. To change it (and the turn signals) will the whole headlight assembly have to be removed like it did when changing the high/low beams?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I haven't specifically changed bulbs on an M, but the front bulbs on almost everything Nissan can be reached by peeling back the wheel well liners, without needing to remove the headlight assemblies.
Big_Tone
Also, does anyone know the part # for that auxilary/park/etc bulb?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Big_Tone wrote:
Fri Jun 30, 2023 11:22 am
If you go to https://www.infinitipartsdeal.com/ and put in your VIN you'll be able to get almost every part number for your vehicle.
VStar650CL
Technical Expert
Rogue One wrote:
Fri Jun 30, 2023 5:56 pm
They have pics of most of the bulbs, too. Marker lamps on most Nissan products are T10 peanut bulbs.
Ilya
I think the marker light is a 168/194 and if you have small enough hands you can get to it from the top, behind the assembly. Or use small pliers but be careful. It's VERY tight. But probably best to just remove the wheel, remove the wheel liner, and go that way. You do NOT need to remove the entire headlight assembly (which means dropping the bumper). That only needs to be done if you are replacing the HID Ballast.
Big_Tone
VStar650CL wrote:
Fri Jun 30, 2023 6:09 pm
Thanks!
Big_Tone
Ilya wrote:
Sat Jul 01, 2023 7:32 am
Ok. Good to know. Thanks!
Big_Tone
I think the bulb you're referring to is the one that's towards the corner of the headlight assembly. The one I'm looking to replace is near/under the turn signal bulb. Is that the same #? I looked at the site, but it's a little confusing to figure out what is what. :wtf2:
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
Both marker/parking lights in the headlight are 194's. That includes the one is the corner behind the amber lense and the one towards the middle of the assembly in between the low beam and turn signal.
Big_Tone
DoN_BLaZe34 wrote:
Sun Jul 02, 2023 7:07 am
Sweet. Thanks! I'm looking for an LED replacement for both since one of them is out.
