Headlight Bulb replace
soltys
Car: 2008 Altima Coupe 3.5 SE 6-speed (Satin White/Black)
2009 Rogue SL AWD - (the wife's)
I'm needed to replace one of the low beams in my 2009 Rogue (non-HID). I just wanting to know is it easier to remove the headlight assembly itself to replace the bulb or is they enough room to fit my non-girly hands behind the assembly to work.
Sorry if this is a repeat but every search I did for this came up with HID replacements
philipa_240sx
It's actually harder to remove the headlight assembly as you have to take the entire bumper off to get at the lower bolts.
The bulbs are easily replaceable from inside the engine compartment. Read your owners manual on pg 8-26. You might also want to remove the intake air tube from the drivers side to improve access. The procedure is on pg 8-7.
Good luck!
soltys
Thanks - That's what I was thinking but just wanted to make sure.
Return to “Rogue Forum”
