headlight bulb removal
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
equlizer
Car: Nissan Versa SL with SVT transmission
well tried taking em out and all that came out was the plug I can see they want to come out but dont. how do you get them out? i want to replace with xenon bulbs i bought.
CodeRed
Car: 2008 Nissan Versa S MT
There are about 3 threads that describe how to remove the bulb. Please search.
equlizer
sorry i was in a frenzy
figured it all out. those little clips are annoying to get off. These bulbs say "color temp 4000K ultra white Xenon gas simulated HID.
will these be too hot for our car?
CodeRed
No, the K has nothing to do with the temperature. It's the bulb color.
feloniousmonk
CodeRed wrote:No, the K has nothing to do with the temperature. It's the bulb color.
And he probably wasted his money too.
To the OP, read this and browse around the site. A little automotive lighting 101.http://www.danielsternlighting....html
equlizer
well it was only $6 for them and i do notice a difference
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Actually, temperature is EXACTLY what "K" means. 4000K means 4000 degrees Kelvin. Different temperatures produce different bandwidths of light, which is what determines a lamp's color.
feloniousmonk
Technically, you're both in the same ballpark. In context of light bulbs (HID capsules specifically) the Kelvin rating describes light "temperature" or "hue". In this case "temperature" is not in the same sense as "today's high is 74 degrees with low of 60". It is a indicator of color in the visible spectrum of light. Brightness, on the other hand, is measured by Lumens.
Return to “Versa Technical Discussions”
