OP,
I had that problem a ton after I put my stereo in. The weight in the trunk was causing the car to sit with the nose up (I desperately need Eibachs) and the beams were flying high. In fact, they are now aimed as low as they can go (they might be a bit too low, but they work fine for me). I think from the factory our lights come aimed a bit high.
dangeris wrote:That's good info Spock...I wonder if the headlights need to be adjusted after we get them retrofitted with projectors or does Brandon already do that for us so it's a plug and play for us
I would double check anyway (no offense to Brandon). I'm sure all of our cars sit a bit differently, so you never know how close his calibration will be. Plus, it only takes a few moments to actually adjust (the hard part is finding a 25 ft long flat surface with a wall at the other end).
