headlight assembly removal question
violet_z
Hey all,I searched and came up with the idea that it is probably best to remove the headlight assembly in order to change blubs. I read that there are 4 screws that hold the front headlight assembly on. My question is how to get the 4th and hardest screw out? It is right in the corner and I am wondering what else i have to remove to get to this damn screw!! you'd think they would make this an easier process, like on the z's :-/
Thanks all,v
f8sjester
which year do you have? for the s14's i know it's just the two screws on the radiator support and the two on the inside of the corner lamp. all of them are completely accessible with a standard socket with a short extension.
