elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Apr 05, 2003 8:08 am
This has nothing to do with the bulb..... Maybe this is something that you all havent had to do..... But there is an adjustment screw on the back of the headlight to adjust it vertically (sorry, brain fart). Here is a direct quote from the owners manual:
The gauge on the side further away from the engine is the horizontal gauge. The gauge thatis closer to the engine is the vertical gauge. The vertical gauge adjustment screw is on the back of the headlight. The air bubble in the gauge should be centered by turning the adjustment screw with an open end wrench. Turn the adjustment screw clockwise (asviewed from the back of the headlight) and the headlight beam will raise, moving the air bubble in the gauge forward. Turn the adjustment screw counterclockwise and the headlightbeam will lower, moving the air bubble backward.
what I am saying is one of the screws to adjust vertically does not do anything. It turns, but it does not adjust like the other side does. Any ideas???
