I searched through the first 2 pages of results for 'headlights' and couldn't find anything... I assume that if the car has a headlight adjustment kit that they can be adjusted to some extent, but my question is a bit more than that.
now because my car is rhd and they drive in the left lane in japan, the light cut (the line where the lights stop beaming) goes from lower right to upper left, ie: right into the face of oncoming comuters.
Despite the humorous look on peoples faces (and you can see their faces quite well), they are probably illegal and although it's amusing when they flash you several times with their high beams only to earn a shot of the actual high beams -- the novelty has warn off.
Can they be adjusted to point in the other direction, and if so, does it involve more work than simply using the headlight adjustment kit?
Thanks in advance to the NICO experts.
