stealthydude »
https://forums.nicoclub.com/stealthydude-u87581.html
Sun Jan 27, 2008 4:56 pm
I have a 1993 240SX that has its passenger side headlight sticking up and wont retract down. The interesting thing is, it works find in one direction., ie., it would go up using the control switch but to make it go down I have to manually rotate the motor by opening the hood.My question is if this could be a faulty motor given that the motor works in one direction just fine.I tried to look for the working mechanism of the motor by reading the wiring diagrams etc, but I cant figure out how the 4 relays and the detector switch work? Could it be one of the relays or the detector switch or the control switch?
Any other areas I should check?
Thanks for any suggestions.
