Tampa G35 Sedan 6MT »
https://forums.nicoclub.com/tampa-g35-sedan-6mt-u77425.html
Tue Nov 20, 2007 11:30 am
I just went to the car and did mine.. you need a philips that has large teeth not the slim one. It works better.
If you are looking at the head light from the front of the car, the screw is on the inside part of the head light. Very easy to get too. It looks like you will be adjusting the fog light but they are both on one screw.
If you are standing over the head light you will see like a U shaped gider and the screw is right be low it.. Get a flash light and it is easy to see.
Good luck with your lights
DJ
Thanks for the tip
Modified by Tampa G35 Sedan 6MT at 12:08 AM 11/24/2007
