95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Tue Oct 03, 2006 8:48 am
you need to understand that since the head gasket gets crushed during installation, and to some extent it gets crushed a bit more after the first several heat cycles (which is why you hear of people telling you to retorque your head bolts/studs after a short period). and since we are comparing different materials and constructions, we need to remember that they will all crush differently under the same force. we should be comparing, if anything, the CRUSHED thickness of a given head gasket. i'm rather sure i've seen at least some companies advertise the crushed height of their gaskets, but you'll have to check before deciding which thickness you need.
in my book, 8.5:1 static c/r is about as low as i'd want to go unless i had a purpose-built race car, in which case i'd probably still run 8.5:1 or greater unless massive boost demanded otherwise. lower c/r makes for worse puttering around town/out of boost driving, which does happen occasionally . of course higher boost levels increase the dynamic c/r, but remember that big cams lower it as well.
just trying to keep the actual physics of what's happening on your minds so you can apply it and go faster .
