Headgasket?
RShih
I noticed my car overheats ONLY in stop and go traffic but when I get going, it drops back to normal and when I drive from light to light its fine. I do spit out white smoke at WOT. I also hear a noise coming from somewhere near the water pump at startup. So I guess my question is...Water pump bad or Headgasket blown?Haven't checked the spark plugs for residue yet. I just changed the oil and doesn't look milky at all. The antifreeze is clear. No leaks but do have a vac/boost leak somewhere.
karmakaze
Car: 98 240sx SE
do you have a fan? e fan or mechanical fan? fan shroud?
RShih
I have a electric fan. I dont have a thermostat.
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
compression test, pressurize coolant system
karmakaze
Car: 98 240sx SE
check you coolant level, check to see if your weeper valve is leaking, check to make sure your efan is wired correctly (i have seen that before).
RShih
coolant lvl is good (no reservoir) efan is blowing towards motor.what is a weeper valve?
karmakaze
Car: 98 240sx SE
when your water pump starts going bad it is a hole that water will leak out of.
