headgasket removal
okinawa drift
Car: 89 240sx SOHCoupe
If you were to remove the head, you would HAVE to replace the head gasket right? since you cant use it again.. does that go along with the bolts too? you can't re use the bolts???
nismojunkie
iirc you can re-use the old bolts, but why not be safe and buy new ones?
tramp_drift240
Car: 1992 240sx SE Coupe
stock head bolts are TTY (torque to yield) meaning they dont tighten as well as they did after the first use. the headgasket probably wont make a proper seal and will probably end up needing replaced in the next month or so, if not sooner.
just spring for some ARP's, theyre reusable time and time again.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
and get a cometic metal head gasket
tramp_drift240
some prefer Felpro headgaskets
but if you go cometic (like i did) just make sure to coat it on both sides with Copper spray-a-seal (like i did)
-RJ-
damn shoulda did that, just finished rebuiling my motor and it sputs oil
tramp_drift240
might be a headgasket leak, shoulda sprayed it.
-RJ-
yea im doing that when i take it out again
tramp_drift240
just make sure the HG itself isnt damaged when you do, or youll have to replace it. reusing headgaskets seem iffy, but if its a cometic, who knows? maybe itll be fine. haha
